Choosing a PSU - Please Help
18 Sep 2013
Hi there
I have decided on getting a new graphics card Asus HD 7970 Matrix Platinum and it has 2 x 8 pin connectors & my 5 year old psu has no 8 pin connectors, so im looking to get a modular psu, min 700-750 watts that would accommodate for my needs. any help would be greatly appreciated
Intel Core i7 3770 @4.8ghz
Asus z77 Sabertooth Mobo
Asus GTX 480 (slightly over clocked (by ~100mhz)
Asus HD 7970 Matrix Platinum (Future)
Samsung Green 16GB ram
SSD + HDD (boot + storage)
Corsair Graphite 600T Midi Tower Case
Thermaltake Tough power 750watt psu (about 5 years old)
Note:
I do care about the looks of my case, not fussed about the actual psu but the cable management etc.
Your setup needs less than 600w at present. If you want to crossfire later, then get a 750-800w.. but otherwise it's a waste.
Also, fully modular is a bit of a gimmick. All the cables that are not detachable in a semi-modular are those you will need anyway, so why would you want them as modular? Yes, it does make the build easier, but I don't think its worth any extra pounds.
How much do you pay for your electricity! And where can I get a deal like that lol?
Nah joking aside it's rather a subjective topic based on how much you use your PC, what you use it for, and the spec of the components.
If the OP keeps the PSU 5 years again and uses the PC 4 hours a day at 425W component draw the gold would save you £5 a year at a unit rate of 12.678 p per kWh over the bronze.
£25 saving over the 5 years covering the extra cost of the gold over the bronze, albeit it a pretty small profit.
yeah i use my pc 3-4 hours per day max. if im honest, idc about the electricity cost. £20-30 is more important for me at the moment since im stretching my budget for a psu. i have not bought a psu in the past five years but Seasonic didnt exist back then and to me OCZ sounds like a better brand, or is that just my perception.
i appreciate the help btw! trying to keep the costs down, any other options?
Yeah I can appreciate that it's not really saving money really, but it wouldn't cost any more in the long run and Seasonic is probably the top brand at the moment, along with Antec as they use Seasonic internals. Some of the Corsair ones also use Seasonic internals but you have to be careful because not all of them do.
I don't know much about the OCZ ones I think they are OK but not the best, I probably wouldn't be happy pushing an OCZ to the limit on a daily basis whereas I would have no qualms about doing that with a Seasonic based one.
OCZ being a better brand in PSUs than Seasonic?
Seasonic not existing in 2008?
that is surely just your perception.
excuse my ignorance. i was only 19 back then, maybe i was only after flashy brands : P
I picked up a Corsair RM series PSU which arrived today, I'd recommend looking at one of those, so they look very good and really quiet.
Andi.
