Cinebench R24 released
6 Feb 2019
R5 5600X @ PBO +100mhz
32gb DDR4 @ 3733mhz CL18
RX 6700XT @ 2845mhz VRAM @ 2150mhz
GPU = 7746 pts
CPU (Multi Core) = 636 pts
CPU (Single Core) = 96 pts
MP Ratio = 6.61 x
Ryzen 7 5800X @ PBO
32Gb DDR4 @ 3600MHz
Geforce RTX 3060Ti @ 2400MHz
GPU = 9610 pts
CPU (Multi Core) = 857 pts
CPU (Single Core) = 98 pts
MP Ratio = 8.74 x
12700KF @ Stock
64Gb DDR4 @ 3600MHz CL18
Geforce RTX 4090 @ Stock
GPU = 35,786 :cry:
CPU (Multi Core) = 1189
CPU (Single Core) = 112
MP Ratio = 10.64
I did some reading up and the 4090 is 124% faster than the 7900XTX at the GPU run on this. AMD yet again have some ways to go before they catch up in this arena.
12700KF @ Stock
GPU = 35,786 :cry:
MP Ratio = 10.64
That makes sense given other video rendering benchmarks, such as blender or adobe premiere also show the 4090 way ahead at rendering workloads
I've found scores for Apple silicon for referencing. A m2 ultra scores around 8000 in the GPU test
  • Like
Reactions: mrk
i9-13900K Stock frequency but running an undervolt and ram set to XMP 7200 , GPU is overclocked . Recently done a Bios update and need to reload my OC profiles hence CPU stock for now .
  • Like
Reactions: mrk
The benchmark doesn’t use RT cores on AMD as far as I know. It could be because of the public AMD drivers don’t have it enabled.
Also the the GPU benchmark needs around 8Gb of VRAM I believe. Anyone with an 8Gb car or lower want to try it out?
  • Like
Reactions: mrk
