Circulation problem
Permabanned
30 Aug 2009
Managed to find 2 extenders for reservoir and fixed the leak issue thnk you BUT upon switching on the pc the water only goes to the first rad and doesnt circulate upwards to the rest of the components.
The reservoir has ample amount of liquid, whats causing this?
Is the top of your reservoir open?
Don't run your PC, make sure only the pump is connected to the PSU and the ATX connector is jumped.
No res sealed the pump came with a atx connector with the jumper may try it.
So far the res is feeding the pump and the pump goes to the 1fan rad but doesnt go any further? Barely 1/4 of the loop cycle.?
If the top of your reservoir is closed it will be an air-tight system, so the air that is already in the system will never be able to escape.
As you run the pump with the reservoir lid off it will circulate the coolant, pushing the air in the loop back through to the reservoir where it can escape out the open top.
Just don't fill the reservoir too full so that there's no risk of it splashing out the top.
of course makes sense will try
Opened res didnt change a thing.
One thing I noticed is when turning power of water travels back higher, if that makes sense?Likes it sucking water instead of pushing it.
The orientation should be right:
Res on top going down to roof of pump then front/face of pump going to rad and rest of loop?
I had a look at your pic and I thought to myself "The only thing which could be wrong is if the outlet of the pump was going into the reservoir.
So yes, you just need to swap the pump around.
The computer shuts down? Or the pump?
Have you checked for leaks around the connectors?
Are you able to view the CPU temps before it shuts down?
OK i will repeat what others have said
DO NOT RUN THE PC TILL EVERYTHING IS FULLY LEAK TESTED.
As the system is not full you havnt fully leak tested the pc should not be on. The only thing that should be powered is the pump, nothing else. Sounds like youve got water where it shouldnt be
EDIT: Extreme where abouts in the country are you? It seams like your struggling a bit with this setup and it might help if someone experienced took a look a tit to take some of the stress off
Tbh mate, that's a right mess in there and it's hard to tell what's going on :)
Aside from your issues, the bottom 120 rad is virtually useless sitting there and I'd be surprised if that 360 (or 420) rad is going to properly deal with all that no matter how efficient 980s are supposed to be.
Have you been filling the loop with everything plugged in or just the pump?
2 360s at top and a 120mm rad bottom, imo the pump was the only component that took some heavy water contact, already ordered a new pump.
Like I said presentation is far from done.See how it goes.
Ok two 360's, cool :)
So you spilled water over the pump? And what about the filling and pump cycling procedure? Was just the pump plugged in, or did you have power going to everything else too?
