service password-encryption
service sequence-numbers
hostname MMJUK
boot-start-marker
boot system flash
boot-end-marker
security authentication failure rate 3 log
security passwords min-length 8
logging buffered 4096 debugging
logging console debug
enable secret 5 ****YOURPASSWORDGOESHERE****
clock timezone GMT 1
clock summer-time PCTime date Mar 30 2003 2:00 Oct 26 2003 3:00
mmi polling-interval 60
no mmi auto-configure
no mmi pvc
mmi snmp-timeout 180
no aaa new-model
ip subnet-zero
no ip source-route
no ip gratuitous-arps
ip cef
ip inspect tcp synwait-time 10
ip inspect name INSPECT cuseeme
ip inspect name INSPECT ftp
ip inspect name INSPECT h323
ip inspect name INSPECT netshow
ip inspect name INSPECT rcmd
ip inspect name INSPECT realaudio
ip inspect name INSPECT rtsp
ip inspect name INSPECT smtp
ip inspect name INSPECT sqlnet
ip inspect name INSPECT streamworks
ip inspect name INSPECT tftp
ip inspect name INSPECT tcp
ip inspect name INSPECT udp
ip inspect name INSPECT vdolive
ip inspect name INSPECT icmp
ip tcp synwait-time 10
no ip dhcp conflict logging
ip dhcp excluded-address 192.168.1.1
ip dhcp pool MMJnet
network 192.168.1.0 255.255.255.0
default-router 192.168.1.1
dns-server ***ENTER YOUR DNS SERVERS HERE WITH SPACE BETWEEN EACH IP***
lease infinite
no ip bootp server
no ip domain lookup
ip domain name MMJ.com
ip vrf forwarding
ip ssh time-out 60
ip ssh authentication-retries 2
username mmjuk password ****YOURPASSWORDGOESHERE****
interface FastEthernet0
no ip address
no shut
interface FastEthernet1
no ip address
no shut
interface FastEthernet2
no ip address
no shut
interface FastEthernet3
no ip address
no shut
interface FastEthernet4
description Outside Net
ip address dhcp
ip access-group 101 in
no ip redirects
no ip unreachables
no ip proxy-arp
ip nat outside
ip route-cache flow
half-duplex
no cdp enable
no shut
interface vlan1
description Inside Net
ip address 192.168.1.1 255.255.255.0
no ip redirects
no ip unreachables
no ip proxy-arp
ip nat inside
ip inspect INSPECT in
ip route-cache flow
speed 100
full-duplex
no cdp enable
ip nat inside source list 10 interface FastEthernet4 overload
ip nat translation timeout 3600
ip nat translation tcp-timeout 1200
ip nat translation finrst-timeout 15
ip nat translation syn-timeout 45
ip classless
ip http server
ip http access-class 1
ip http authentication local
ip http secure-server
logging trap debugging
access-list 1 remark ***HTTP_SERVER_ACL***
access-list 1 permit 192.168.1.0 0.0.0.255
access-list 1 deny any log
access-list 10 remark ***PAT ADDRESSES***
access-list 10 permit 192.168.1.0 0.0.0.15
access-list 100 remark ***ALLOWED TO SSH TO ROUTER***
access-list 100 permit ip 192.168.1.0 0.0.0.255 any
access-list 101 remark ***ALLOWS ISP TO ASSIGN ADDRESSES***
access-list 101 permit udp any any eq bootpc
access-list 101 remark ***RFC2827_FIltering***
access-list 101 deny ip 10.0.0.0 0.255.255.255 any log
access-list 101 deny ip 172.16.0.0 0.15.255.255 any log
access-list 101 deny ip 192.168.0.0 0.0.255.255 any log
access-list 101 deny ip 127.0.0.0 0.255.255.255 any log
access-list 101 permit icmp any any echo-reply
access-list 101 permit icmp any any time-exceeded
access-list 101 permit icmp any any unreachable
access-list 101 deny ip any any log
no cdp run
banner login ^CCThis is my router. There are many like it but this one is mine.
^C
line con 0
transport output telnet
line aux 0
transport input ssh
transport output ssh
line vty 0 4
access-class 100 in
exec-timeout 120 0
password 7 10585A0B1C044108191679
login local
transport input ssh
scheduler max-task-time 5000
scheduler interval 500
end
