- 22 Dec 2006
- Around Town
If you are an Xbox Live subscriber, had your modified Xbox console banned from Xbox Live, were not refunded a prorated sum for the time left on your subscription...
I know 4 people with shop bought, un-modified consoles that got banned so Microsofts "detection" is pretty poor before you consider in also know 2 people with modded consoles that were not banned. I suppose people having bought second hand consoles have it wors, rather conveniently lining Microsofts pockets. If they didn't milk things quite so badly (hard drives) people may be inclined to sympathise with them, but I doubt class action will do much.
That having been said the EU has repetitively done Microsofts for it's business practices over the past few years (basically treating the uk like the us) and while the OS side of the business seems to have improved the console side has declined but what can you do.
If this makes it to the eu court then they almost certainly will get done again, chances of that are...
There is no way you know 4 people with legit (not modded in any way, including WD 120GB drives or datel mem cards) that got banned, can you imagine the uproar that this would cause if it happened?
You may have read on a forum somewhere and it is utter BS
lolpirates
Ermmm, you don't get your Live account banned, its just the console...
They "corrupt" your profile, or something
No they don't, they want your profile to work so you are more inclined to just replace the XBox rather than think 'screw it' and get a PS3.
No I mean, on the console you used that gamerprofile on, they delete all the digital certificates from the HDD so if you ever played pirate games then tried connecting that profile from same HDD to XBL, it just not work.
Point i'm trying to get across but failing to do so because I have such rubbish explanatory skills issss:
When you're banned, and if you carry on playing games on that banned xbox + gamer card and get achievements etc. still then try putting that into a legit one to update the gamer score, it wouldn't work because it'll come up as "corrupt" so recovering the gamer card is the only way.![]()
