Classic 120gb IPod problems
19 Jul 2011
I have been trouble with playing songs on my iPod everytime I play a song it will just randomly skip to another song, but they work perfectly in iTunes. Can anybody suggest anything?
Thanks
If it is the HDD, depending how much you value the ipod (and if its not in warranty) you can pick up a new 120gb drive for about £60, or upgrade it, provided the logic board supports it, to a 160gb for about £80. Taking them apart, if its anything like my 60gb 5th gen video, is pretty simple, mine had a faulty headphone jack. Pop open from the sides and your in :D
