Clay bar advice
Man of Honour
17 Oct 2002
Hi all,
I parked my car under a tree and now it's covered in really nasty tree sap. The only way I have found that will remove the tree sap is my Claybar.
Problem is, does the Claybar strip wax and polish?
Last month I spent 2 days applying 3 coats of Autoglym Super Resin Polish, 2 coats of Extra Gloss Protection and 2 coats of Collinite 476S :(
I've got these bug removal cloths, i've also had them work on tree sap, might be worth a try i think you can get a small pack of 10 or something.
[TW]Fox said:
It took me days last time, which I don't have at the moment :p
Thats because you went overkill. A silver car does NOT need 3 coats of super resin, nor 2 coats of extra gloss.
If you apply it properly you only need the one coat of each. Then your collinite.
Could you not soften it with something like AG Intensive Tar Remover and buff it away with a soft cloth?
Also slightly off topic question but why Extra Gloss Protection then good quality wax as well? Can't you just put the wax straight onto the freshly polished paint?
I just followed what they said on Detailing World :o
Liverpool-Lad said:
More to the point, why did it take you 2 days? Are you half-man half-sloth? :D
Left 30-60 minutes between each coat, but then I guess I did properly clean inside and out, and do the glass.
On two E39's :p
