Has anyone used the bottled cleaning stuff made by Arctic yet?.....
I brought some a while ago, think it was £6 or so.
And although there is lots of household things you use for cleaning i cannot tell you guys how much you're missing out.
Its around £6 and will clean loads, and i mean plenty of HSF, cpu's, gpu's, and what not before it runs out, it works absolutely brilliant, just follow the instructions and you have a perfect surface for your compound.
Its like the "shall i use the bog standard pad or arctic" question.
Until you try it, you won't appreciate how effective it is.
Please share opinions, disagree if you will, i don't mind.... its a forum after all
