That will just blow all the debris around, you'll need a decent vacuum at the same time. Possibly even a dry paint brush to get to the tricky bits.Whats the best way to clean inside the PC, i heard compressed air is good ?
Yes, "compressed air" is actually liquid in the can and decompresses into a gas before spraying. So you don't shake the can, and you have to keep it upright, or else you spray the liquid out of the nozzle.I heard you have to keep the can upright else it can blow liquid into the PC ?
Andi.
I don't clean mine anymore, something always seems to stop working after lol, if it's not broken don't fix it(clean it)
