ClockTuner 2.0 for Ryzen... do YOU have a Golden Sample? Post your results here. :)
Caporegime
8 Sep 2005
Utopia
Hi guys. Lovely clickbait title I know, but a new tool for CPU's has been released called CTR2.0 (ClockTuner 2.0 for Ryzen) and it is available from here https://www.guru3d.com/articles-pages/clocktuner-2-for-ryzen-(ctr)-guide,1.html
Installation (please read!):
  • Download CTR and unpack the ZIP archive in a directory of your choice
  • Then download the Cinebench R20 archive and extract the contents of the archive to the “CB20” folder (this folder is located inside the CTR folder).
  • You can find the log file in the "CTR LOGS" folder within the application directory and copy and paste from there.
The tool does a few things similar to Ryzen Master, but what interested me the most a the moment was that it performs an analysis on each of your cores and gives them a rating as to how well they OC.
Golden Sample = Woohoo you lucked out and got a good clocker!
Silver Sample = Nice, you got a decent clocker.
Bronze Sample = Wooden spoon
This is going to make for some nice light-hearted testing where we can either celebrate or commiserate with how our CPU's are rated. I guess it may also depend on your cooling, but if you have good air cooling or an AIO then you should get a reasonable test.
My results were surprisingly accurate and are actually what I settled at for 24/7 operation:
DIAGNOSTIC RESULTS
AMD Ryzen 7 5800X 8-Core Processor
Max temperature: 58.1°
Energy efficient: 3.8
Your CPU is BRONZE SAMPLE
Recomended values for overclocking (P1 profile):
Reference voltage: 1250 mV
Reference frequency: 4500 MHz
Recomended values for overclocking (P2 profile):
Reference voltage: 1325 mV
Reference frequency: 4575 MHz
Recomended values for undervolting:
Reference voltage: 1125 mV
Reference frequency: 4250 MHz
Bronze Sample though, waaahhhhhh. :( :D
What do you get?
PS: Please also state your cooling as this makes a big difference to results. :)
DIAGNOSTIC RESULTS
AMD Ryzen 9 5950X 16-Core Processor
Max temperature: 56.2°
Energy efficient: 3.9
Your CPU is SILVER SAMPLE
Recomended CCX delta: 175
Theoretical maximum CCX delta: 200
Reference voltage: 1100 mV
Reference frequency: 4475 MHz
Reference voltage: 1000 mV
Reference frequency: 4050 MHz
No idea what this all means .........:confused:
Iwas curious with reading this, i ran my 5800x in eco mode as was hitting 82 in cinebench r32 so put back to default and ram this.
DIAGNOSTIC RESULTS
Max temperature: 55.6°
Energy efficient: 4.22
Your CPU is GOLDEN SAMPLE
Reference frequency: 4725 MHz
Reference frequency: 4800 MHz
what would you do next with these results
DIAGNOSTIC RESULTS
Max temperature: 67.4°
Energy efficient: 4.08
Reference frequency: 4650 MHz
Reference frequency: 4400 MHz
:D
DIAGNOSTIC RESULTS
Max temperature: 64°
Energy efficient: 4.12
Reference frequency: 4675 MHz
Reference frequency: 4750 MHz
Reference frequency: 4425 MHz
DIAGNOSTIC RESULTS
Max temperature: 63.3°
Energy efficient: 3.99
Reference frequency: 4600 MHz
Reference frequency: 4350 MHz
DIAGNOSTIC RESULTS
AMD Ryzen 5 5600X 6-Core Processor
Max temperature: 38.6°
Reference voltage: 1150 mV
Reference frequency: 4525 MHz
Reference voltage: 1300 mV
Reference voltage: 1025 mV
For normal day to-day usage I leave it running at stock, but for gaming it’s running an all-core overclock of 4.85ghz @ 1.35v.
DIAGNOSTIC RESULTS
Max temperature: 60°
Energy efficient: 3.65
Reference frequency: 4150 MHz
I should take out this hot piece of junk and smash it with a hammer! :rolleyes:
mine from the other thread
I suspect mine is no better than average but I'm not sure I want it confirmed or told it's worse. I'm still clinging to "ignorance is bliss" at the moment... :D
DIAGNOSTIC RESULTS
Max temperature: 61.6°
Reference frequency: 4550 MHz
Reference frequency: 4625 MHz
Reference frequency: 4300 MHz
Was hoping for gold but what you gonna do.
DIAGNOSTIC RESULTS
Max temperature: 52°
Energy efficient: 3.82
Reference frequency: 4275 MHz
Phoenix deactivated!
DIAGNOSTIC RESULTS
You can read the article explaining everything here https://www.guru3d.com/articles-pages/clocktuner-2-for-ryzen-(ctr)-guide,1.html
DIAGNOSTIC RESULTS
It says you have a good clocker. Try the stated overclocks at those voltages to see if they are accurate? You could use the Ryzen Master tool (google it, takes an hour to learn) or just try it in BIOS.
DIAGNOSTIC RESULTS
Wow, very nice sample you got there!
LOL... as long as it runs at stock specs it's all good. :D
Give in to peer pressure and do it, do it, do it.... :D
Here's mine... not too shabby
DIAGNOSTIC RESULTS
Max temperature: 61°
Energy efficient: 4.19
Phoenix ready!
DIAGNOSTIC RESULTS
Energy efficient: 4.03
Reference frequency: 4700 MHz
Reference frequency: 4375 MHz
