Cloning boot partition - Clone not booting
20 Apr 2004
Rugby
My old Samsung F1 1Tb was split into two partitions, one around 250gb which was my boot and the rest was for games.
I have purchased a Samsung F4 320gb (the new boot drive) and a F4 1TB (the new games drive). The plan was the clone the respective old partitions to there new homes on the new drives starting with the boot partition. The problem is that I've cloned the old boot partition to the new F4 320gb but when I try and boot from it nothing happens after the Bios, just a blinking "_" like there's nothing to boot from :confused:.
I have tried both Clonezilla and HDclone to the same effect, I'm presuming there missing something as I've seen the cloning of boot partitions done without issue before (well I'm pretty sure I have).
Any suggestion as I relay don't want to reinstall windows
Thanks in advance
I think windows writes some boot files to all partitions. on my setup, i have one drive with 7 on it and another running xp, but through the 7 bootloader. If i unplug on of the drives, then i cant access the other (i get the same blinking _ you mention).
As to how to fix it ... dunno. You could try cloning the other partition to the new 1tb drive and booting off just those two drives (unplug your old one)
well im trying Ghost 15 now,
there was a option to make the copyed/clone to drive "active - (for OS boot)" so hopefully this will do it.
35mins to go till i find out
