COD4 res problem
4 Feb 2007
Nuneaton, UK
I changed my res to a mode my monitor cant support by accident.
Id these anyway I can change it back with a console command or a way to start the game in safe mode or something so I can get it back again?
Thanks
COD4\players\profiles\'your name' and the config.cfg has an entry in it seta r_mode "your res" just change it to a working res
having trouble finding that, do you mean in the game folder?
C:/program files/activision/cod4/ etc?
Cant find it in there, maybe im bein stupid.
Thanks for your help so far
C:\program files\activision\cod4\players\profiles\your profile there are files in that folder one of which is config.cfg and if you open it with notepad and search {ctrl +f } for the resolution it currently is now , you will find the entry and be able to change it to a working res.
For me its:
C:\Games\call of duty 4\players\profiles\para\config.cfg
So, yes if you installed to the default DIR, then C:\Program Files\Activision\...
OK, I looked and I dont have a players or profile folder
In C:\Program Files\Activision\Call of Duty 4 - Modern Warfare
All I have is
Docs
zone
miles
main
Mods
pb
And some other files like the exe and some .dll's
No set res command I can blindly type into the console?
how are you going to get to the games console if you cant get into the game with your res being screwed?
you must have a player profile as this is what you do upon first loading the game is set up a profile.
Browse though C:\Users
I'm on vista 64bit with uac turned on and mine is stored in
C:\Users\michael\AppData\Local\VirtualStore\Program Files (x86)\Activision\Call of Duty 4 - Modern Warfare\players\profiles\Lunix
Hope this helps.
Thanks Lunix, thats where it is.
I managed to do it already though using another monitor that supported the res I set.
Cheers guys
