if your using vista.
Vista codec pack and x64 component tools (if 64bit).
VLC is good. But WMP is a much better player.
LOLWUT!
VLC is good. But Media Player Classic is a much better player. and WMP sucks donkey balls!
I'm running Vista x64 with just the Vista Codec Pack, I haven't found any need to be running the x64 components because I'm using the 32-bit player and it plays nearly everything including my MKVs. I watch most stuff on my TV via my Xbox which has XBMC installed which plays nearly everything as it's based on mplayer and ffmpeg, only hidef and certain quicktime things it won't play but thats due to the hardware not being up to it (it's only a 733Mhz CPU with 64MB RAM after all).
II haven't found any need to be running the x64 components because I'm using the 32-bit player and it plays nearly everything including my MKVs
and have it use FFDshow to upscale anything less than 720p resolution.
