james.miller said:well thats a huge assumption isnt it? i dont care wether the pack is illegal because, and here's the important bit, i dont NEED it. ffdshow does it all so why do i need more?
When did I say you needed it?
Energize said:When did I say you needed it?
If I worried about everything like you people do I don't think I'd be able to get through life lol.
Tony Williams said:
THE CHOPPER said:I second that , this codec pack sorted all my problems out. I class it as essential
squiffy said:Clueless. I use a HTPC which lots of different video files and no need to install lots of codecs. FFDSHOW will have sorted out, most likely.
Stop giving out bad advice Tony.
Energize said:People prefer different things get over it.
Audio [version 4.2.0.0]squiffy said:Features of K-Lite Codec Pack 2.80 FULL version :
ROFL! I don't need to say anything more!
Energize said:And by the way it doesn't install all that, you choose what to install at the installation wizard.
Energize said:You didn't say anything, what does quoting the features list show?
squiffy said:If you can't figure it out for yourself...if you have any clue about HTPC/video setup's you'll realize 99% of these codecs aren't required. From that list I would need.
FFDShow
MPEG-2, using Theatretek and using TT as the player
FLAC encoder and directshow, only directshow because in Media Portal flac wasen't working. FLAC Works fine in Winamp without the FLAC filter though.
OGG encoder for my encodes.
Realtime Alternative
That's it! oh only need Quicktime Alternative for site browsing, I have no QT movies.
So if you choose 1 codec that steps on the toes of another, does it automatically deselect it?
For instance, if you decide to install the DivX decoder, does it stop you from installing the XviD one? It's not so bad if that's the case - otherwise it's just a quick fix for people that haven't got a clue what does what, so whack on a collection of dodgy material.
