Cold Cathode Installation, Need Help!
Take the molex from power connector away,
Now unplug the molex from your DVD drive and plug it into the molex connector then the
spare molex connector goes back into the DVD drive.
I'm 90% sure this is how it works. Dont forget to make sure the switch is on so the Cathode
works mate.
Let me know if it works.
I'm no expert or anything but I am pretty sure those two red wires need to be joined. Don't think the lights will work with only one cable...
connect the 2 red wires either to a switch or directly(make sure their shielded)
the molex you ??? is just a pass through so you don't lose one
i cant believe i didnt think of putting them together -_- for some reason i thought they had to go into the mobo or something stupid like that , first time building a computer and i know little, but i thought id would have a go anyway lol gotta start somewhere and yeah i had the switches were on, on the box
thanks for helping me all of you, if it works and i havnt put up a new message then assume it has worked :)
