- 29 Sep 2003
- Newcastle upon Tyne
Hi all
When I run a hot tap the combi boiler fires up and heats the water. However, as the pressure drops, the boiler switches off and stops heating the water. I'm left with just cold water coming from the hot tap. I can force the boiler to start heating the water again by turning the tap on some more, but at this point I'm pouring quite a considerable amount of water down the drain.
Does anyone know why my boiler might be shutting off heating the water despite the fact that it is still running?
I should note that the heating works fine and that the boiler has sufficient pressure in the heating system (1 bar).
Many thanks
M.
Many thanks
M.
