i saw the tech designs for the 2900, ati were making a mistake and i even tried to warn them about it. thier loss.
LOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOL
Why do they have Daemon Tools and YASU installed? And what does the x on their volume icon mean?
There's two cores and two pcb's.
9800GX2 > G92-450-A2
8800GTS-512 > G92-400-A2
8800GT > G92-270-A2
Looks like we have our selves a local GPU Engineer, you go mav, tell 'em how it's done!
not for free i won't
You made nothing more than a guess ffs, nothing more nothing less and are now going around here like you're an authority on gpu engineering. Your levels of clairovoyance are about on par with mystic meg "someone might win the lottery" oooh how does she do it? its a gift.
with those pieces of technical marvel i'm surprised they aren't beating you're door down with a 200K contract.
'performance per watt ratio' wow ...you'd be chief engineer in a snap
so it uses 2 x G92 cores, thats something we all already know.
only thing not known abou the gx2 is if it will use the 112sp GT core or the 128sp GTS core.
8800GS is a cut down G92, 96SP, 192bit memory interface with 384MB memory.also check on the 8800gs, im not sure but i think it also uses the G92 core.
