big steel boxes sound a promising start for containing fires.
especially with some decent insualtion.
I wouldn't care whatsoever. I don't plan for things that aren't likely to occur. If it blows up, ah well.
Preserving their quality of life, or acting in an entitled manner? They are largely one and the same. My need is greater than yours, etc. I believe what Glaucus was advocating is a planning system where the needs of society are placed ahead of the desires of the individual. We build where it makes sense to build, rather than where the existing residents complain the least.
What's the back of a fag packet calculation for battery storage to smooth out the grid vs. pumping water up a tower and letting it out again when you need more beans?
Tower? Won't work. Water is too heavy and voluminous - it would need to be one hell of a tower!
If we take the efficiency of the Dinorwig plant, for example:
Capacity: 6,700,000,000 Litres
Weight: 6,700,000,000kg, or 6.7 million tonnes.
Energy storage capacity: 9.3GWh.
1.39GWh per million tonnes of water.
1.39kWh per tonne of water.
The battery pack in the current Nissan Leaf is equivalent to 21.5m^3 and 21.5 tonnes of water in Dinorwig. The Leaf's battery pack is only 0.49m^3 and weighs 294kg. To put it another way, that's 0.00319kWh per kg vs 2.5kWh per kg. By size and weight, the battery is vastly more efficient.
Stored water is a decent system. But we don't have enough suitable natural sites, and building a man-made structure would be challenging and inefficient. Plus, you've still got to move all that power over long distances. It's part of the solution, but not the solution itself.
OP I don't think you need to worry as after abit of research they will be using Samsung batteries![]()
when you say efficient though how long does a leaft battery last and how much does it cost?
Dinorwig has been open nearly 30 years iirc.
obviously a battery is better interms of energy density per weight but efficency i doubt.
water scales better.
Preserving quality of life. If we turn into that society, we've lost our democracy and turned into a dictatorship. Too many times the opinions of those that have to live in an area are ignored, it shouldn't be made worse.
