Hey dudes today I got my Corsiar 800d and H50 and some new memory.
Install went fine, moved everything over all fitted nicely and everything looked great.
However now i get no signal to my monitor when i boot the pc, at first i thought i had done some thing to the gfx or the memory so swapped them out one at a time with my old one's and still nothing.
When i press the power button the computer sounds like it comes on for half a second then goes off then comes on again and tries to boot. All the fans come on my gfx card comes on. there is a green light on my asus pq5 pro so that seems to have power but all i get on the monitor is no signal.
Anyone got any ideas pleease? I will buy cookies for whoever helps me solve this...
update :
OK so did some fiddling about today when i got in form work.
Seems that my asus wont boot with more than 2gb of ram in
It runs fine with my 2x 1gb of pc 6400 and fine with 1 stick of my 2gb pc 8500 but if i try up it to 4gb it wont work.
Any reason for this as my mobo should easily be able to run the 4gb
Anyone any ideas
