Man of Honour
- 17 Feb 2003
- Chelmsford
My current system uses Masterkleer 7/16" ID squeezed over 1/2 barbs. These are very tight and I'm not sure how easy these are going to be to remove. No clamps used.
However, for my new system, I'm thinking of using Compression fittings. I take it that if I choice 1/2" ID compression fittings that i'd only need 1/2" ID tubing rather than the tighter 7/16", which would be pointless?
Here's what I'm looking at :
EK-FC5870 V2 - Plexi (Non Reference ATI 5870)
HEATKILLER® CPU Rev3.0 1366 Water Block
10 x 1/4" BSPP - 1/2" ID - 3/4" OD Compression Fitting
5m of 1/2" ID - 3/4" OD XSPC Blue/UV Blue Hose
Any other combinations or recommendations?
