Compression Fittings
Meh cable management is the equivalent of staring in the mirror all day and worrying about your hair.
Temps are my only concern:)
What cable management :p
Your are quite right but do note that cables do in some respect get in the way of good airflow :D
Otherwise looking good ...
True the case labs is like a cave though, so airflow not much of a problem :)
I just don't have the patience to make things look too bling thoughN jsut want goo quality components, good cooling and even more importantly minimal noise. On the latter I have always ran an FC this is the frst build without oneM one of the reason I went with this board is that it has seven fan headers, all conrollable in bios and software, I just hope the lowest duty cylcle works as I have WS fans in there :)
Should be two pumps in there as well but one of them was dead, not sure how long it has been dead for as it was in my old build but didn't work in my new one. One of the disadvantages of running two pumps off one pwm header:(
what ive done is got fan splitters, what this does is it takes the regular 3 wire from the fans and splits it so it can control 2 fans but only reads one, i have my blue wire on the one that reads (my pump is in a molex anyway) and any fan on the one that isnt read because i adjust my fans by noise anyway so the need to read the speed isnt there.
I think its the best way to be sure that its all working without losing the ability to control more fans.
Yep that would work. Another good thing about thsi board is that it has two pwm fan headers for the CPU alone, so when I get my replacement I'll just stick it on there and have proper warning.
