Computer randomly freezing.-Help needed PLEASE.
I have no other psu to try, but I am now running off integrated graphics, with my ATI Radeon hd 5700 card temporarily removed. If it still crashes, I am going to remove ram one by one, then swap psu. If all of that fails- I will RMA the motherboard.
Ok, so I used my old brothers graphics card, and it crashed. Using my integrated graphics, it hasn't yet? Please may someone make sense of this.
Why can my computer run with integrated graphics, but when I put an graphics card into the computer, it crashes?
Ok now my computer screen crashed on Integrated graphics. It froze, and the screen displayed loads of vertical blue/green lines on my screen. Its obvious my computer is dying big style, but can someone please tell me whether it is the psu or motherboard?
There comes a point to stop posting on forums and take it to a shop before you wipe put all your system parts. there is no way any forum member can tell you 100% what is wrong without touching the system
i'm still sticking with the PSU..... Is there no way you can borrow one off a friend or something?
I agree with Dave0w here though, you should take it to a shop to diagnose the problem properly as there is only so much advice that can be given on a forum.
it sounds like it either motherboard, cpu, ram or psu. so unless you have the spares to swap out, then its probably time to either take it to a shop, or buy a new pc :(
