- 1 Feb 2007
Why does my pc reboot everytime i shut it down?
Do you know where this is, I'm not good at the BIOSMNuTz said:I had this problem after messing about in the BIOS, there is an option to automatically power up whenever it powers off, i think its in case of a server losing power so it can reboot itself and doesnt effect remote users.
then it may be Advanced Power Management causing a problem. Never a problem unless its a motherboard designed before xp. everything is brand new, days oldfirewallblocked said:What spec is your system? If you are using a really old system like a pentium 3 for typing letters etc to keep your main Ultima Extreme SLi 8800 GTX free for serious stuff like gamesthen it may be Advanced Power Management causing a problem. Never a problem unless its a motherboard designed before xp.
If your system is newer try taking out all pci cards (not your grapics card) and unplugging usb attached devices I did have an old yamaha soundcard that worked fine but caused restarts on shutdown.
