Only being able to get a (single) dynamic IP (with the rDNS fixed) might count as a disadvantage, but I suppose it depends what you're looking for.
If you're referring to cable, my IP apparently shows me as being in UB6 (I wish
)Only being able to get a (single) dynamic IP (with the rDNS fixed) might count as a disadvantage, but I suppose it depends what you're looking for.
)if your not into downloading, then virgin is a contender, however, if you a bit-torrent fiend like me, there is only one ISP, and thats BE.
im on VM 20MB. it's great.I've just read up a bit more on this traffic shaping virgin do, and it doesn't sound so bad to me. You can download as much as you like, but after 350mbs in peak times your connection gets halved ? ( 20-10 )
Why do you say that ? that makes absolutely no sense tbqfh
on 20MB connection speed u get 3GB bandwidth limit in peak time (4pm till 12am) if u go over your 3GB bandwidth limit your speed will drop down to 5MB for 4 hours
Your gonna want to get patch. Crossover is just for PC to PC sorta thing, you wont need it if your using a router. and i think a lot of devices these days can actualy use patch as crossover if needs be, but dont hold me to that.
*ediT*
also Cat5E will do fine, just get good stuff
Cat6 is only needed for >1gbit networks afaik
