Dr Who said:Cool unit, but save the fitting costs by buying at Halfrauds...
What you save on the PP you will easily spend on fitting costs elsewhere
Not exactly hard to fit a headunit tbh! Would rather do myself than have halfords muppets doing it!
GT3 said:Not exactly hard to fit a headunit tbh! Would rather do myself than have halfords muppets doing it!
Dr Who said:Fitting a headunit is easy, getting factory fit ones out can be a real pain tho...
Those muppets do them everyday, and muppet or not, they will do a much better job than most.. Proper ISO adapters, correct tools..
Firestar_3x said:But your talking about a saxo though, fitting it to a VAG car or a (Proper car) can require more effort, oftern parts of the dash cover the edges of the unit so to get the tools in you need to remove part of the dash face or alloy trim etc.
In the saxo its a case of 4 pins pull the unit out unplug the ISO and antenna rip the cage out new cage in plug in the ISO / Antenna slide unit back in a thats it.
Dr Who said:PS. If you damage the wiring and her car goes up in smoke, what comeback does she have on you?
I wana thank you for that link, some very nice clothes on there.mightynimrod said:If you got to Freemans catalogue (no competitor i think) then it's £99 inc fitting at your home.
Im going to get one
link - HERE
quackers said:Has anyone ever tried to get an ipod/other mp3 player hooked up to a ford cd player.
Is it possible?
vygec said:Ive pretty much decided i want one of these:
http://www.caraudiodirect.co.uk/product_info.php?products_id=4109. Would the standard vw speakers in the car handle this ok?
