Cooking Oil for use in a Wok
Don
7 Aug 2003
Aberdeenshire
Made the mistake of using olive oil as it was the only thing I had to hand. What's best to use that won't leave black carbon deposits?
Peanut oil doesn't leave a taste at all. Sesame does so fair enough. Sunflower oil would work also, and is what I use when out of peanut.
Aye, I've got sesame oil, never thought to use it for anything other to add flavour. Is bog standard veg oil ok for the high temperatures?
Standard veg oil is refined with lots of different vegetable oils, generally. It's designed to have a high smoke point so you'll be fine. Vegetable shortening, a semi-solid; kinda like lard) isn't appropriate though. Though, I find vegetable oil gives off that distinctive 'fry' smell. As such, I use sunflower oil instead.
Sesame oil doesn't have much of a taste really, the stuff you buy in supermarkets is smoked. The oil itself would normally be fine for wok cooking but pretty hard to find unlike groundnut oil which works well and can be found any place.
