- 18 Oct 2002
- Nr Colchester, Essex
All looks good. Most of the recipes I have seen, along with BBQ pit boys and the completion BBQ folk agree it's not worth putting the rub on in advance. Just take it out the fridge, add the rub and leave it 30mins to warm up before cooking. *However* This would be for the BBQ with the intention of smoking it. So it might make a difference. The additional flavours are normally found in the bark and don't really penetrate that far into the joint.
6 Hours doesn't sound very long either, you kind of have to use an it's done when it's done method, as if the fat doesn't get up to temp it won't break down. So you get stringy rather than melt in the mouth. The internal temp needs to get to 180F and cooking should be between 230-250F.
I quite often smoke shoulder joints for pulled pork. I will try and document it next time. Last portion I had last month I used as much chilli sauce as you would normally BBQ, it was rather hot, I think I gave myself Chilli Euphoria. Good though!
