Cool Speedtest
12 Oct 2003
Leicester
Just found THIS speed test and thought it was pretty good!
Its a 1mb\256k up fixed line.
Unfortunately I havent been able to persuade the landlord that this ISP has problems and that a switch is in order...
Is he or she blind as your speeds are on a par with dial-up :rolleyes: (at the landlord not you)
I think I might be going mad but it appears the NTL 4mb lines switch back to their old 80kb speed now and again... well they do with this test.
VERY ODD. Speeds are TWICE as good when transferring from the new york server than the london server.
sr4470 said:
"As long as it works" was his reply. Besides, he signed up for 12 months...
Even so, if I had signed up for a connection as slow as that then I would get my ISP to log a fault with BT and if they are not willing to do that then I would ask for my MAC code as that speed isn't acceptable on a 1 Mb connection.
I cant do that myself as I'm not the account holder and dont have the password. :rolleyes:
