Cooler Master HAF 912 Plus
Coolermaster HAF 912 Plus Case - Black @ £68.98 inc VAT
Cooler Master adds another new member to the HAF series, the HAF 912 Plus. To carry the mission of providing the best thermal solutions, HAF 912 Plus supports two 120 mm for external radiator and high-end CPU coolers. Furthermore, the spacious interior accommodates two 200mm fans and two - 120mm fans for better and superior airflow yet, enough to fit 12 devices and high-end GPUs such as Radeon HD5970 and Nvidia GTX 480.
- Superior cooling performance support up to two 200 mm and two 120 mm fans
- Front 200mm fan with brilliant Red LED provides the best airflow to HDDs
- Removable 3.5”HDD cage provides enthusiasts more convenient installation
- Customized neat cable management
- Dimensions 230 x 480 x 496 mm (WxHxL)
- Weight: 8,45 kg
- Motherboard Support: ATX, Micro-ATX
- Front Cooling: 1x 200 mm (19 dB(A), 700 RPM, Red LED) or 2 x 120mm fans (optional)
- Top Cooling: 1x 200 mm (19 dB(A), 700 RPM) or 2 x 120mm fans (optional)
- Rear Cooling: 1x 120 mm (17 dB(A), 1.200 RPM)
- Side Cooling: 1x 140 / 120 mm (Optional)
- 5.25" Drive Bays: 4
- 3.5" Drive Bays: 7
- 2.5" Drive Bays: 4
- Expansions Slots: 8
- Front I/O Ports: 2x USB 2.0 / 1x eSATA/ 1x Audio In/Out
- VGA Card Size: Up to 39 cm
Only £68.98 inc VAT.
ORDER NOW
This may sound dumb as I havn't read it anywhere but is it right they are releasing 1 version in different areas? USA = normal, Europe = Plus, and asia = Advanced? Whats that about?
This is correct. The USA version is grey interior has less tool-less kit in and a 120mm fan at the front. The European version in my review above and at OcUK is black interior tool-less and 200mm fan at front. There is going to be another version in ASIA called the 912 Advanced which will feature a window with similar features to the 912 Plus (European). Confusing... no idea why this has been done but those in the states have come off worse!!
I'm guessing it's because the different regions have different levels of competition at each pricing niche, and are tailoring their versions to fit these niches.
Hardware Canucks have a pretty good run-down of the US version of the HAF-912 here:
As Mishima says I think they got the poorer end of the deal, but it would be interesting to see how this basic version would do over here priced aggressively at Antec 300 levels.
Agreed that the americans got boned in getting the bare spec. Just hoping they just testing the responses of each type and see the response/demand before deciding which others to ship off to where. Hope so anyway because its just weird to release 1 version in each place.
Something as basic as the box is even worse. EU get a nice colourfully branded box whereas the Americans get a brown recycled thing!!
