coolest running low-end cpu
28 Aug 2005
I'm looking to build a really low spec pc as I have a terrible idea for a case mod I want to try out. Anyway, I'm looking for the coolest running CPU I can get. its speed is irrelevant as this PC will be for writing documents and general web surfing. I won't be overclocking and my budget for cpu + mobo is about £100 but would pay more for something ideal.
If there's nothing that would run much cooler than my current spec I might use that and just build a better main machine.
Exentia said:
Im intrigued.
hmm, I don't really want to say what it is until I finish (in case I totally mess it up and look like an idiot) but I've done the worst of it (IMO) so far ok. still, should be finished in a couple of weeks (if i can get the things i need by then...) and i'll post pics.
Exentia said:
couldnt you go for P3 or something. :confused:
erm, I don't know. Yeah, I mean anything would be fine, I just don't know what the normal operating temps are for anything pre AMD 64 tbh (or anything intel at all for that matter).
however, should have mentioned, I need to run it on a mATX board and as I only have SATA drives lying around, might be nice if the CPU would be compatible with a board that supports it (i can't really put in PCI cards of any description for this mod - so guess i'll need onboard sound and vga too)
alucks said:
cheers. I'm guessing higher wattage = higher temperature?
edit: i was being stupid
Yes, & also Process, i.e. 130nm, 90nm, etc :)
I think for your project and what you intend to use the machine for, aim at the Athlon XP-M's. Mainly because, I'm sure you can pick up a cheap one ;)
thanks for your help. yeah, the xp-m's seem like a cheap option. think im almost certainly gonna head that way.
thanks again.
yeah, I read something about underclocking somewhere and they only managed to drop the temps by about 7 oC. Maybe it wasn't a great source but if that's typical it doesn't really seem worth it. I always thought semprons ran really hot as well.
so on OcUK i could get a sempron for about £50 (inc vat + p&p) and I'm looking at about £10 less for a mobile processor. guess i should think about mobo options.
which do you think?
You have loads of options here. Probably too many for me to list.
If buying new the most sensible option on a budget is defintely the sempron route. £45 for a chip and £40 for a mobo with integrated gfx. (incidentally the nvidia 6100 boards are good - but the atis are potentially even lower power)
Most semprons will (going by 3000+ venice ratings in tcasemax) probably use between 32W and 44W at stock volts. From there you should be able to undervolt the chip significantly.
If the motherboard allows (or you can use Crystal CPU-ID to do it in windows) it you will probably be able to undervolt the chip as low as 1.1v at stock speed (saving nearly 40%)
Some boards allow you to go down as low as 0.8v cutting the power to roughly 1/3rd of it's original amount ...... however you would also have to start underclocking the chip dramatically too - which reduces power even further!
In theory a 32W venice running at 600mhz and 0.8v would use approx 3.5W full load! :O The sempron would be similar.
If you want to do it even cheaper and processing power isn't an issue there is also the option of using xp-m chips and undervolting (abit boards tend to go down to 1.1v on socket a). Then there are via epia chips or amd geode. Some of the p3s are very low power too.
Personally - for the £85 that a sempron + mobo will set you back and the extra processing power etc you have it's the one i'd go for.
Drop me an email if you want further advice on a specific chip range - I've run low power machines using p3s, xp-ms, bartons, semprons and socket 939 chips. I even wrote my dissertation on the subject :)
(The 754 and 939s are my favourite partly because they are initially low pwower and can run on such low voltage but also because you can get some awesome cpu coolers for them)
sargatanas said:
what about a Celeron M? those things run cool and are really cheap now . :)
nah, I think the mobos for them cost a bomb. i don't really wanna spend that much for something which is gonna turn out to be a disaster anyway.
Cheap S754 board and a Sempron would probably be best.
