cooling basics
yes mate that means you can have two 80mm fans, one at the back and one at the front. i take it your case doesnt have a side window then? at least with two 80mm fans that would increase your airflow in your case!
another option you have xirokx is that if your case has only fixings for 2 fans then modify it so that you can fit more :D
depends how much you do/dont love your case!
you running it at 2.55 now? stable? pick some numbers for the lottery and send them to me in a PM pls :D
whats a pci exhaust blower?
