cooling fans help
I added a temporary way to lift the case 7cm to allow less restricted intake of air for the PSU
Sorry I meant 50mm all the way around fan/vent intake.
You raise it 70mm but blocked one side of PSU intake and 2 sides of middle vent. Not the same but still might help some.
Try using something like spray can caps, children's blocks, thread spools, etc.
Here is how I raise mine
images
Caster base is 2 levels to allow access to filters without taking computer off of base ;)
This (cutting edging) was already made long time ago, the edging is a Edge Trim U Channel, I bought from chilledPC sold per meter, there are many ways/tools to cut out a grill
I have used aviation snips, hand nibblers, power nibblers, die grinders with cut-off wheels, jigsaws, etc. in the past and was curious what tool you used.
Thanks for ChilledPC as source of edging.
