Cooling Problem with Gigabyte 3D Aurora
21 Jun 2004
Berkshire
Basically I have a Gigabyte 3D aurora case and have had it for a few months now. I am having absolute hell trying to get the temps right.
I bought the case based on good reviews all over google and the fact that I got it cheap and its nice and roomy inside.
I have the clear sidewindow version.
I am running with the standard fans, 12cm front (I removed the dust filter) and 2x rear 12cm fans and a PCI exhaust blower. With a Asus Silent Knight II CPU cooler, have also uses Intel Stock cooler and a Freezer7 Pro beforehand.
My C2D E6400 at Stock settings with stock voltage is around 46/49c idle, or near enough.
I remove the side panel of the case, and temps go down to around 35c/40c.
I really don't understand how I can improve airflow in this case. The cabling is relativley neat, there are no obstructions and it really doesnt seem to be warm inside the case either.
I previously had an Antec SuperLanboy and though yeah I will get a big new case, and the 3D aurora had 2 rear 120mm fans so airflow had to be good right? Obviously I was wrong.
Does anyone have any suggestions, ive been scratching my head for a few days now?
Cheers
How have you got the fans arranged? It sounds like they may all be blowing into the case or similar.
Check that the front are intakes and the back are outlets.
Other than that I am stumped :/
Fans in the case are pre-modded/wired etc and are all facing the right direction.
The fans in the case are not really powerful, but they are moving a reasonable amount of air. :/
The problem is the intake is restricted by the drivebay and the sidemesh upsets the airflow. I know people who have Aurora's and get better temps with the window panel as opposed to the mesh panel.
i was going to say that but then i would check other temps like mobo or gpu and then check the hsf and say the thermal paste. gotta get it just right :)
glad you got it sorted though.
