Core speed wrong?
30 May 2007
Hi all. Gigabyte GA-P35-DS4, E6600 Core 2, Geil 6400 Black Dragon 2x2GB
Am going to overclock but am confused before I start :D
CPU-Z is showing:
Core Speed: 1600.0 MHz
Multiplier: x6.0
Bus Speed: 266.7 MHz
Rated FSB 1066.7FSB
I've read in another thread where the guy showed the same core speed, that the multiplier needs to be increased to x9?
My Advanced BIOS settings already show the CPU Clock ration as x9. Have typed out my BIOS settigs below. Can anyone tell me where I'm going wrong please?
Many thanks
Phil
Robust Graphics Booster: [AUTO]
CPU Clock Ratio: [9X]
CPU Host Clock Control [Disabled]
x CPU Host Frequency (Mhz) 266
PCI Express Frequency (Mhz): [AUTO]
C.I.A.2: [Disabled]
System Memory Multiplier (spd): [AUTO]
Memory Frequency (Mhz) 800 800
High Speed DRAM DLL Settings: [Option 1]
Performance Enhance: [Turbo]
DRAM Timing Selectable (spd) [Manual]
CAS Latency Time: 6 [5]
DRAM RAS# to CAS# Delay: 6 [5]
DRAM RAS# Precharge: 6 [5]
Precharge Delay (tRAS): 18 [15]
ACT to ACT Delay (tRRD): 3 [AUTO]
Rank Write to READ Delay: 4 [AUTO]
Write to Precharge Delay: 6 [AUTO]
Refresh to ACT Delay: 52 [0]
Read to Precharge Delay: 3 [AUTO]
tRD: 5 [AUTO]
tRD Phase Adjustment: 1 [AUTO]
***** System Voltage Optimized *****
System Voltage Control: [Manual]
DDR2 OverVoltage Control: [Normal]
PCI-E OverVoltage Control: [Normal]
FSB OverVoltage Control: [Normal]
(G)MCH OverVoltage Control: [Normal]
CPU Voltage Control: [Normal]
Normal CPU Vcore 1.35000V
Full Spec:
Gigabyte GA-P35-DS4
geil 4GB (2x2GB) PC6400C5 800MHz CAS 5-5-5-15
E6600 Core 2 Duo
Tagan 700W Power supply
EVGA GeForce 8800 GTX KO ACS3 768MB
Auzentech Medidian sound card
Samsung 500GB SATA drive
That'll be "Speedstep", it'll be reducing the multiplier (and sometimes fsb) of your CPU from 8x to 6x only when the computer is idle or doesn't need more than the performance that it gives with the lower multi. Run a benchmark like Orthos, and keep an eye on CPU-Z and you should notice the multiplier increase back to normal and the Mhz resume back to normal too.
Thanks.
Disabled EIST and C1E but cant find a Speedstep option.
CPU-Z now showing:
Core speed: 2400.0 MHz
Multiplier: x9.0
best
Phil
