- 26 Dec 2002
- Derbyshire
Just a heads up in case anyone was waiting for a particular fix
http://www.alcpu.com/CoreTemp/
- Add: System tray icons configuration.
- Add: Support for Intel's latest CPUs.
- Add: ClearType font support.
- Add: Time\Date column to the log file.
- Add: Always on top option.
- Fix: Core Temp does not proprerly display temperature and CPU select fields.
- Fix: Log file layout.
- Fix: Hide\Show does not properly Minimize\Restore window.
- Fix: Core code names aren't properly detected. (Intel)
- Fix: Incorrect\Missing CPU rating when not using stock\maximum multiplier. (Intel)
- Fix: Wrong CPU clock is reported when using EIST\non-maximum multiplier. (Intel)
- Fix: Wrong detection of Merom based CPUs.
- Fix: Single core Athlon 64s and Semprons reading -49C constantly. (Rare)
- Fix: C2D M0 rev. report very low temperatures. (Tjmax to 100C)
- Fix: Layout and display of tool tip text in the system tray. (Now shows a core per line)
- Change: Log the start and end of a session even if logging is disabled.
- Change: Settings and Systray settings windows appear in center of main window.
- Change: Rename "Tjunction" field to "Tj. Max" to make things clearer.
