Well it's nice to finally post a proper update
! Firstly @ AMG: Yep, fans go between the case body and the top mesh, and the rad fits inside the case. That's the main reason I chose this over the 650D.
Also started doing a bit of cable management (can never start too early
!). I don't have equipment to solder, so it was creative 'folding' to make the cables the right size. 600T's cable management is HEAVEN btw, HEAVEN. The next time I try to sort cables on a Lian Li I might have a stroke.
Guess what arrived in the post today
. About a week late, but meh...twas the only place with the quad rad in stock.
Magicool 360:
Phobya 480 Extreme:
Had a bit of a nervous few minutes moving the HDDs and seeing if the rad would actually fit
Yay! 1cm spare. The rad is a bit wider than the official measurements, but the 600T is a wide case. With both case sides on:
And both rads in position:
I'm going to be using the rest of today to plan out tubing routes. I think it's going to be a bit tricky as the HDD cage is where I want the pump to be, and also as I'm using GPU only blocks. My pump (MCP 655 with EK block) is also rather large and it's going to be a struggle to find room. Since we're on that topic, just leak tested the pump+block this evening and was all fine:
May post my final route later. Will order the remaining fittings etc tonight and hopefully get everything on Wednesday. Need to work out how to attach the quad rad to the case too.
