Hey all
Just fitted 2 Xigmatek 140 fans in the case one on the bottom pulling in & the rear fan pulling out, you will be pleased to know that they have taken 5 degrees off my Gtx295 at idle!
No extra noise either so I am really pleased with the result.
So I have managed to get a better airflow into the case.
Hope this helps some of you
Cheers all
Good to know mate if I need the additional air flow while keeping things quietIts the same in mine but I replaced the stock 140mm fans bottom & rear with the Xigmateks which seem to pull more air in hence my drop in temps, plus I have 3 120mm Sythe flex's running at 1200 rpm pulling air out in the top of the case.
