** Corsair Carbide 540 High Airflow ATX Cube Case - NEW COLOURS **
  • Thread starter Thread starter rjk
  • Start date Start date
Heres mine. Although Ive swapped the 2 140s for 3 Zalman 120s from my old case.
Nice looking build ...nice and tidy too :)
Yeah I also have 3 Zalman 120s from my old case ( K-62) via Molex and they are very quiet ...want to get some 140s though that are just as silent via Molex too
Thanks. :)
The other side is a total contrast! What you dont see cant hurt right? ha!
Yeah I took mine from the Z9 Plus. I liked that case, but this one ticked more boxes for me. Airflow, space, presentation.. far better!
** ITS BIG AND WHITE AND CUBE SHAPED **
I guess I dont need to explain this too much
Corsair Carbide 540 High Airflow ATX Cube Case - Arctic White (CC-9011048-WW) @ £129.99 inc VAT
The unconventional design of Carbide Series Air 540 utilizes dual chambers to deliver cooler air to your CPU, graphics cards, motherboard, and memory without your drives or power supply getting in the way. The included custom Air Series -White LED intake and AF140L exhaust fans provide great airflow performance at lower noise levels than typical case fans. And, you can mount up to six 120mm or five 140mm fans, with 280mm top radiator support and room for a 360mm radiator on the front panel.
Like all Corsair cases, Carbide Series Air 540 is designed for fast, neat, and satisfying builds. The tinted, oversized flush-mount side window lets you show off your work.
Features:
- Dual-chamber Direct Airflow Path™ design for outstanding cooling potential
- Clever, space-saving design still offers lots of internal volume
- Includes three High Performance Air Series AF140L fans for better, quieter cooling
- Tons of expansion room for high performance air cooling and liquid cooling
- Full side panel window
- Front dust filter
- Black interior
- Cable routing cutouts with rubber grommets
- CPU cutout in motherboard tray for easy CPU cooler swap-out
- Dual front USB 3.0 ports with internal connector
- Headphone, Microphone front ports
- Eight expansion slots for quad GPU installations
Specifications:
Fan Mount Locations
- Front: 2 x 140mm White LED (included), 3 x 120mm (pre-spaced for radiators)
- Top: 2 x 140mm or 2 x 120mm (pre-spaced for radiators)
- Rear: 1 x 140mm (included) or 1 x 120mm
- Dual 3.5" hot swap bays
- Four 2.5" tool-free SSD drive cages
- Maximum GPU Length 320mm
- Maximum CPU Cooler Height 170mm
- Maximum PSU length 200mm
Only £129.99 inc VAT.
ORDER NOW
