Out of the two options mentioned in the title, which would you recommend in terms of cooling, noise, reliability, warranty and looks?
Thanks.
Thanks.
I have bought corsair few weeks ago to replace my Noctua. There was no issue installing it at all, when it comes to cables please see picture below, this is the best i could achieve.Yep, I was worried about the DIMM slot issue and surprised it's not been discussed more. Seems like a fairly big design flaw. The Corsair is cheaper at the moment and I've been put off slightly by the comments regarding NZXT's CAM software. Did you find it easy enough to neatly hide the cabling?
https://imgur.com/a/hvRQh [/IMG]
Noctua is definitely quieter if you run your pc on full whack, when gaming or just normal pc usage i'd say both make the same noise. Just set the fans to low rpm. Pump at standard setting is whisper quiet.Cheers for that, looks great Is it pretty quiet in a similar way to the Noctua?
Warranty nzxt but Corsair purely due to CAM still being a pain in the rear.
It is and it's a shame as there hardware and support is super.Read quite a bit on CAM and it's made me go Corsair, seems like the software is a mess.
