Or do it in a case that has airflow tuned / optimized for the system in it.
Or test the AIO/CLC with radiator as exhaust which is a more logical way to do it considering everything in the case is air cooled except what the CLC is on. But even that is not optimizing case airflow for system in it. The point of AIO is to cool one component. There is no 'point' about it not using the same temperature air as an air cooler would. In fact the 'point' of testing them with same temperature air flowing through them is so we know the actual cooling ability of one versus the other and not the falsely inflated numbers resulting from different air temp going into them. But more to the 'point' why would it be good to use a CLC as intake heating the air going into a system with everything being air cooled except what CLC is cooling? That is totally illogical.
Not having a desktop 7 years makes no difference, nor does your not caring about results back then. True not all cases support all coolers. But the lower cost, more dependablity and lower noise of air coolers makes them the logical choice in most cases (no pun). If someone wants to use a CLC or hopefully an AIO that is not a CLC that is their choice. All I'm trying to do is educate the consumer as best I can before they make their choice. I don't think I said to get D15, but D15 will clear almost all RAM and many cases.
Actually from what you are posting here I do know a lot more about coolers than you do .. and people do actually see that. No idea how cars got into this discussion. A good air cooler is generally a better choice than a CLC, but there are rare exceptions. Air coolers being better than CLCs is one thing. What a user chooses to buy is another. Much of the advertising, review testing, and other marketing is geared to draw the buyer into CLCs, and the reality is they are not the better choice. The cost more, generally make more noise (pump noise is always there), don't last as long (and when they die there is no cooling until replaced .. not cheap) versus an air cooler that only thing that can go bad is the fan, which usually give plenty of warming by making noise, system will still work at low load or with whatever fan user has held on with rubber-bands until suitible repalcement is in hand .. and new fan is a frction the cost of new CLC.
£20 more than NH-D15 which at £84.95 is most expensive air cooler in OcUK's store (with PhononicHEX 2.0 being same price and not near as good a cooler). Genesis and D15 SE-AM4 are close and Dark Rock Pro 4 is £79.99. All the others are sub £75. There are now several CLCs in this same price range, but again not as good as the air coolers for all the already listed reasons.
Sorry, I got personal in this post, but your saying I don't know what Ii was talking about when it is so obvious you are the one who doesn't kinda left me no choise.
