Fairly low powered then. I suppose the pump compares more to the mini Alphacool DC-LT more than any other pump. The black ice rads have significant restriction but I’m thinking if the H100i uses the same pump with a 240mm rad, it should be powerful enough.
That said, the Chinese eBay has ID cooling cpu blocks/pump separate for DIY custom AIO’s. I may be tempted to buy one and build my own AIO just to see how it compares to the Corsair.
I think the Alphacool DC LT 2600 is about 100 L/h flowrate and Alphacool DC LT 3600 is 120 L/h .. about twice the Asetek \h60 pump spec of 40 L/h and Asetek 545 pump spec of 61 L/h spec. |I found Asetek pdf for that data and think I have those pdfs filed somewhere.
If it's the same pump IDCooling uses on Frostflow + I believe it is rated 96 L/h and 1.2 m lift.
http://www.idcooling.com/Product/detail/id/111/name/FROSTFLOW+ 280
