You would have a lot more customers if you included the blower type fan.
Tell me about it! If it helps they are doing on with all HG10 SKUs henceforth including the N1, so maybe they can make the fan available for sale separately as well.
Does the corsair cool the vrns better?
It does, unless you add extra heatsinks to the VRMs when using the NZXT G10.
But out of the box it provides better cooling.
Lol thts quite funny i have nzxt brackets and corsair blocks u have corsair brackets and nzxt blocks
Can you mount that CPU cooler on top? If you can, then you can add another AIO cooler for your 2nd card.
Would you be willing to swap it out for a Corsair bracket If I am able to provide you one?
Correct, future variants will have the fan included. There is a good chance that we will offer them as a spare part.
No I tried the RAM and top red heatsink gets in the way
What i would like to do is swap one for a corsair and keep the other as the nzxt and do a vrm comparison and see how much better the vrm cooling on the corsair is.
Suppose a corsair cooler would look nice with the duel h55's h100i corsair 730t and corsair 850m lol
I like that, make a VRM temp comparison and share your results within the community. Send me a PM so we can discuss the details.
It will surely look great with your 2 H55s, H100i, 730T, and CX850M - Brand loyalty![]()
What can I say other than WOW! Temps already a good 20+ c difference. Quiet, Looks superb and performs superb, all while not breaking the bank..
Plus and Bad points
+ Looks superb, corsair really done a great job with the bracket "personal choices here"
+ Much lower Noise over stock or aftermarket coolers "Depends on your choice of fans and speed"
+ Better temperatures and chance to push your GPUs harder without hitting the max core temps
+ Easy to install, I had little issue getting that Backplate of the GPU but that was because MSI choice if adhesive sticky pads.
+ Can be used with a wide range of AIO water coolers to get even better temps My reading are from a H75 and a Corsair 750D with the front cover on.
Leads me to my only complaint.
- Must use stock reference fan, Ok if you bought a Reference 290/x but because I was using Aftermarket I had to look around. Lucky enough a guy on here sold me two. Thanks spoffle
Corsair are ment t be soon shipping the bracket with there own blower fan and also bundled with one there coolers.
would be 10/10 but for now 9/10 it as to be...
Very happy!
So this bracket works with NZXT coolers as well? Strange that Corsair states hydro series only :S
Looks like a couple of HG10 N1 units are coming my way so we'll see how the included fan is!
