hey gang, hope everything's treating you well.
am doing my first solo build in close to 20 years, so I feel like I'm learning how to ride a bike all over again haha. I wanna get the Corsair ICUE H150i Elite Capellix cpu cooler, as it looks awesome and I want it to match up with the other RGB fans on the case.
the case I have is the Corsair ICUE 4000X, which has two mounts for radiators: room for a 240mm radiator on the roof (which is being used by my 6900-XT) and room for a 360mm radiator on the front, so I'm "stuck" with using the front mount for this.
The issue that I have is how much using a radiator with fans on the front of the case will disrupt the airflow, as the fans are currently set up so the top and bottom fans draw air into the case while the middle fan pulls air that falls into the dead space between the top and bottom fans out of the case. I absolutely love this idea as it implies that you can create an area of high pressure within the case that will prevent dirt from sneaking in through other gaps, and I'd absolutely love to retain that feature.
has anyone got experience with this kinda setup, or can say "the radiators will do little to block air intake" and "the middle fan on the Corsair ICUE H150i sucks air out of the case while the top and bottom fans pull air into the case"
cheers in advance!
cheers in advance!
