@ DrDeathhand, you asked:
Yes you can BUT:
This wouldnt be easy modding and arguably wouldnt be worth the effort unless you placed the entire top with a custom made mesh.
To be honest, I find the FCU some what obtrusive and pointless, but CM shipped with it when they could have raised their case ~1" and had more expansion space in the 5.25" bays. They could have easily pushed the boat and put the inbuilt FCU in a case side panel; there is that much space in them.
For the rest of you, updates soon. I'm just reinstalling hardware and powering up!
==> No more ****** netbook.
But because your mounting them on the top part I was wondering if you are able to mount 3x 140mm here --> http://img98.imageshack.us/img98/7260/20120728143018.jpg
Yes you can BUT:
- Look at the two screws that are right of the bee, and left of the first Noctua. The 140mm fan can fit here; but those screws and fittings will get in the way. So to have one fitting you will need to come up with a way of attaching this top part to the case, without screwing in here, by use of [ brackets.
- These are the only places that the Fan Control Unit (FCU) is screwed in. without this it looks sutpid, plus the top mesh rests on one side on this FCU housing.
- This top unit also has no fittings for a 5.25" bay, so you cant put a resesvior there easily if you were to take out the FCU.
- More importantly, with 140mm fans, most of the 3rd fan will be underneath the FCU. There is v.little exhaust here. It'll go through the mesh, but it'll be noisy.
- The fan holes already cut in the case dont align with 3x 140mm. Unless you have a metal saw, fitting them wont be fun.
). Mounting underneath doesnt give you aircooling potential as its so clustered. You'd end up with still pockets of air in the corners where there was no suction.
