- 6 Aug 2011
Hi guys
Bit of an odd one I cant get my head around. If anyone could help I'd greatly appreciate it.
PC has been working fine up until yesterday.
First issue. Yesterday
Downloading an update on steam, got to the end of the update and it said disk write error.
Moved said game to C: drive instead of the other drive I have for games, updates fine.
Shutdown fine no issues
Second issue. Today
Same problem, different game wouldn't update due to a disk error.
Installed crystaldisk to check drives are all healthy, they are.
Uninstalled Steam to try and reinstall and see if that fixes problem.
After shutting down and restarting, my WiFi adapter is saying in device manager "This device cannot start. (Code 10)"
After multiple restarts I've noticed on startup it's taking an extremely long time to get through the post screen and boot into windows and when it does, it's almost like windows is stuttering, the sound is jumping and only partially playing. It stays the same when you move the volume slider. Sort of fades and stutters in and out.
I've tried restoring back to the 24th of this month, long before I had any issues with no luck.
I've just recently managed to get into the BIOS but it's laggy, extremely laggy, I'm talking like I move the mouse and it moves on screen 10-15 seconds later?
Anybody seen anything like this before?
Specs are below.
Ryzen 9 7900x
Nvidea 3080
32gb ddr5 6000mhz
Gigabyte aorus x670 elite ax
Second issue. Today
Specs are below.
Ryzen 9 7900x
Nvidea 3080
32gb ddr5 6000mhz
