Hi all
I have just built a watercooled SLI system - my dream PC. Finally had the money to burn. However - turned out I needed to spend a bit more than I planned to as I had a mishap with one of the 680s
Knocked off a few resistors at the bottom of the card, just above the PCI-E connector.
Got a couple of pics showing the damage and a comparison pic from a non damaged card. Pics are a bit blurry but the difference is easy to see:
Damage
No damage
EDIT: I finally figured out why those components got dislodged. When I removed the stock cooler I pressed the cooler from one side to loosen the thermal pads. I did this from the top of the cards, down towards the pci connector. This caused the cooler to hit those components and dislodge them.
Any tips on possible repair options?
Knocked off a few resistors at the bottom of the card, just above the PCI-E connector.Got a couple of pics showing the damage and a comparison pic from a non damaged card. Pics are a bit blurry but the difference is easy to see:
Damage
No damage
