It's called burn in.
MYTH
overclock it, make sure it passes orthos for 24hrs and then leave it and enjoy using your new cpu.
Rubbish! It's been proven
Microelectronic items have a time to performe. Ie you TV or hifi is better once it's been on for an hour but over 100+ it gets lots better.
Use it as it is then abuse it. It allows all the diaeltics to settle with useage. Any flaws will show.
Just being on will do for a week. I never turn my hifi off
Regarding hi fis, the only thing that improves or change with time is speakers. This is physical as the cone is a moving part and loosens over time. The 'diaeltrics settle' stuff is if course complete mumbo jumbo.only certain things need runing in, as mentioned allready a car also tvs.
Not cpu`s but the thermal paste that you apply to the cpu needs a running in period i read in the instrutions after that the paste dispates the heat better.
