Lian Li A10B. Super case!!Big.Wayne said:What case is that btw?
Legend said:Lian Li A10B. Super case!!![]()
It is Lian Li's rip off the P180 basically, so I would expect it to look similar.melbourne720 said:Weird, the looks a lot like my P180 with tuniq attached! The layout is the same, and I have black PSU cables.
edit: What's that blue thing in the middle of the case, on the right?
Legend said:It is Lian Li's rip off the P180 basically, so I would expect it to look similar.![]()
Legend said:The blue thing is a Silentmaxx enclosure for my Raptor. Keeps it very quiet indeed.
Silentmaxx keeps it at same temp as well. Two SATA's have fan blowing on them, but Raptor is only 1 degree warmer inside the enclosure.melbourne720 said:Raptor for boot and a RAID for space, nice.
What board is that?
I think it's 1200rpm max, you could still turn it down... As for it being a problem, you could check the cfm of both the tuniq tower and the S-Flex. If the S-Flex is particularly far behind it you might notice a slight increase in temps, but I shouldn't expect it to be worth worrying it about!Proc said:With the S-Flex your limited to 1200rpm
I wondered this myself before I switched it, but I could find no specs on the Tuniq fan which stated how much air it moved - i.e the CFM figure. But I couldn't run it faster than about 1200RPM anyway otherwise the noise just drove me insane! The Scythe fan I have in there now is super quiet at 1200RPM and my temps are great, so I highly doubt you'll have any issues. There is always going to be a small tradeoff for sound vs temps though I think. Unless you opt for watercooling. But unless you go to the extreme one way or the other, your actual performance will not be affected.Proc said:Only thing i have is that the original fan in the Tuniq can be speed controlled, so if it gets hot turn the fan up. With the S-Flex your limited to 1200rpm, could this be a problem or does the S-Flex shift a lot more air than the standard one?
