CPU lapping guide
Nice one Mr.T, good guide. Gives the people who haven't done lapping a good idea of what to do, if it's being made a sticky could be a good idea for people that have done lapping a few times to add some of their tips as well.
Minstadave said:
Ooops forgot you didn't need my help for that, just ignore me, nothing to see here :D
I was going to add you to messenger but I'm using a Linux distro ATM and couldn't figure out how to add people to my contacts so asked Jokester to change the thread title, sooo errr.....can you add me to messenger? :o
Will do :)
Does lapping affect the lifespan of your CPU negatively? Or would it in fact prolong it, given that it allows (ideally) for cooler temps??
:confused:
If you do it right there is no reason why it would effect the lifespan of the cpu. If anything as you say keeping the chip cooler can only be positive.
Overclocking your cpu is more likely to shorten you cpu lifespan as your pushing the limits of the technology.
To check the final flatness, hold the CPU (or waterblock etc) at 90 degrees to your monitor whilst displaying this file, with the edge of the IHS on the center line. The reflected lines should continue smoothly with no wobbles or distortions: http://www.thermochill.com/guides/LappingGrid.pdf (zoom it in a bit too)
A mirror finish is NOT required to get it to reflect. Even a rough block will reflect the image on the monitor at the correct angle.
And reference this thread: http://www.ocforums.com/showthread.php?t=329453&page=3&highlight=lapping+grid
Examples...
1) NOT flat - http://www.employees.org/~slf/flat/grid1.jpg
2) Flat - http://www.employees.org/~slf/flat/grid2.jpg
Examples...
Wow, pretty clever (or maybe im just thick lol), thanks, will give it a go soon, ill get some pics for you guys too!
CarlD said:
I only have 400 , 600 , 100 , 1200 sandpaper... will it be ok if i skip the 800?
Yeah should be fine, do most of the work @ 600 and get to as much copper as I did on my 800 photo. Then go straight to 1000 & 1200.
Good Luck!
Looks like something I may do, not really happy with the temps I get at the moment, will atleast check the contact when I take the chip out!
