CPU running at 100% normal?
25 Sep 2014
I am rendering something on Cinema 4d and my CPU is constantly running at 100%.
I just wanted to know if this is normal and will not harm my pc?
My PC Specs:
Intel i7 5820k 3.30ghz
16gb ram
Cheers
Ah ok so it is a good thing. It is still really slow!
Will overclocking my pc make much of a difference?
thank you for the quick reply
I have the corsair h110 280mm liquid cpu cooler.
I have not checked the temperatures. Not sure how to check it other than in the bios. Which would mean stopping the rendering to reset the computer.
Install coretemp or hw monitor for your temps. Can you not pause the render ? I thought you could in Cinema 4D?
Ok so I have installed hw monitor.
Temperatures seem fine I think.
I was not aware you could pause the rendering. I will look into that.
